looking into other calipers instead
c5s are a poor choice
I have some CTS-V 4 pistons but cant use those unless I go to 18s.
Other option is to find a a rotor thats 330-340mm and has same offset as the 5th gen Camaro.
I already have some 14inch rotors from a Camaro SS but those are too large for 17 inch wheels.
Is anyone running 5th or 6th gen Brembo’s On the rear? I have 6 Gen Brembo’s on the rear and my Boss 338’s are not cutting it. I need about a 10mm spacer but that will put my tire into the fender. I know the Ridler 650 will fit with about 3mm clearance but I would like something similar to my Boss wheels like the Ridler 695. The car is a 1980 Camaro Z28 with the stock 10 Bolt. Thanks
Curious if anyone has had the profile 5 fikse wheels with Cts v gen 2 6 piston brakes and what your front/backspacing/offsets were. To get them to fit around the brakes.
