Oops, I did it again. I have an f-body again
#101
Under the k-member, if you have a stock one. FWIW, I tried and tried to get UMI to add a jack plate to theirs. Maybe Ryan will still do one that way. And on the axle in the rear.
In fact it's funny. GM tells you not to jack a Corvette up by individual corners for exactly that reason. And it's got a full frame.
__________________
#104
def following. Mr. Strano any idea if you are going to be producing a harness bar? or can I just call dibs on the one in your car once you replace it lmao
#105
I might, but not in the next month or two.
Until I do, or get the roll bar in this car, it's not coming out.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
#106
Cross posted to the "Project" thread too:
Fastest laps today. Brake kit worked well, but I did not get the pads bedding in well enough on the street causing some buildup issues. That in turn caused a nasty shaking on the brakes. New rotors on for tomorrow, we'll see how that goes.
Everything else working great. No failures on new part testing.
In car:
Clip a friend snagged from Turn 10 during that same session
In car:
__________________
