C6 base rotor on C5 brake conversion
Hi,
I read that the C6 base model Corvette front rotors are more robust than the C5 Corvette rotors. I believe they are a bit heavier (more metal for heat) and the vanes and center are of a more performance design.
Is this true? I have Corvette brake conversion on my Camaro and it is time for new rotors. Currently have C5 rotors but if the C6's are better, I would like to use those. Thanks
LS1TECH Sponsor
But as I recall the C6 rotors are not curved vaned like the C5's. They are the same thickness overall, the vanes are actually smaller than the C5's so there is less airflow but more mass. It's a trade off of sorts. I stick with C5 stuff most of the time, because they cooler more efficiently. I think GM went to a heavier but less airflow rotor because it saved them some $$$ only having to have one part number for the front and one for the rear where the C5 had 4.
Footnote. This is how GM works and why I think this. My C6Z has only two part number rotors from GM. Trouble is the front is actually curved vane, but meant for the LF... the RF is not only not straight vaned, but the curves are backward which is not good at all. Hell the drilled holes on the RF get plugged with brake dust much more than the LF because of it. And no, I don't love drilled rotors but that's what is required in the class I autocross in. I have slotted ones I run on the track.
I have a ton of rotors. C5 or C6. If you decide on which ping me and we can get you taken care of.
__________________
