squeaky rear suspension and squeaky brakes!
Hi guys, just picked up a 99 ta. Has 59k mi on it and a couple weeks owning it I've noticed a ton of squeaking behind me on the driver's side. I swear I heard a metal clunk one time coming to a stop when I had the TTops off once too. The rear end seems floaty on the hwy too. I suspect I need new rear shocks.
Also, the brakes squeal pretty loudly. Does not sound like a normal brake pad squeal but more metallic. Pads in the rear look like they still have some meat on them. The front pads look new. Additionally the rear rotors look a little thin and the rt rear one has a groove in it. I think she needs new rotors.
What do you think and what options do I have to fix these issues without breaking the bank.
Thanks guys!
Thanks guys!
LS1Tech Premium Sponsor
Check all of your bushings and the sway bar end links. These cars are getting old enough now that these pieces are getting deteriorated and allowing excess movement. Rubber begins to squeak, and you begin getting metal to metal contact on some pieces that lead to squeaks and uneven feelings. I would Identify which ones are bad first and replace those, as bushings are not fun to change, and can add up quick
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
The factory rear shocks are probably the biggest downfall on these cars IMO. Rear shocks will most likely cure the highway boat feel, plus they're easy to install and don't cost nearly as much as what the fronts cost. Koni Str.t shocks are a good choice to look into, I believe they're in stock as well with some vendors on here.
The clunk/squeaking could be quite a lot of different things. First thing that comes to mind are the rear bump stops, but with your car not having that much mileage, they still might be in good condition. Noises can be caused by literally anything that is loose in the rear of these cars. Again, at 59k miles, I don't expect a bushing to be that far gone that it would make a loud clunk sound tho. They may be starting to deteriorate, but I wouldn't guess to the point where they would be clunking. As BMR said, sway bar bushings and end links would probably be the first to squeak, check those out.
For the rear brakes squealing, check and see that both rear calipers can easily slide on the guide pins. On my other car, one guide pin was stuck inside the caliper bracket which didn't allow the caliper to move freely as it should, and for whatever reason produced a nasty squeal when I pressed on the brakes.
Also, when does the squeaking occur? IE when going over a bump, turning, regular driving?
Thanks for the tips!
As far as the squeaking, whenever I go over a bump (speed bump, my inclined driveway) and when turning. Basically, whenever therw is load on the right side.
I saw something that looked like it was rotting and rusty. Touched it with my finger and was just falling apart
Freaking gross! This is a view of the driver's side rear. I shimmied over to the other side and it looks the same....I couldn't get any further under to inspect more due to the huge stock muffler hitting my chest. I'll have to jack it up and look but from what I could see, bushings and stuff looked good.
Nice pics. That helps out a ton. Looks like el cheap shocks ya got there. Don't worry, I had Monroe Sensa-Tracs on mine when I bought it. It was awful. Nice rear bump stops too Looks like they're enjoying life
