Would it even help?
Old Dec 1, 2016 | 07:49 PM
Project_Reaper's Avatar
Default Would it even help?
Hey guys, so my car has been down for 2 years now for a slew of new mods and I'm currently stuck at a fork in the road bc I don't want to waste money. The car is being built to go compete in the LSFEST grand champion event, that being said it needs to be beast at autocross. Ive installed a 6 point cage, the car already has SFC`s and tower brace, so my question is, with the SFC's, STB, and 6 point cage...would upgrading the front and rear sway bars even yield much difference? or would cash be better spent on new Springs or shocks?
Old Dec 1, 2016 | 08:22 PM
Corvett z07's Avatar
Both!
Old Dec 2, 2016 | 07:04 AM
Thumbs up
Originally Posted by Corvett z07
Both!
weeeelllll...If my tax return comes back enough, I most likely will. However Im hoping someone has had a cage and then upgraded to bigger sway bars or vice versa, that can chime in on if they felt any noticeable difference in handling. I dont want to drop $300-$400 on sway bars if the cage and SFCs will be enough. Then that cash could be set aside for better heads.
Old Dec 2, 2016 | 07:23 AM
79_T/A's Avatar
A roll cage has absolutely nothing to do with your sway bars. I'm not sure what gives you that impression.
Old Dec 2, 2016 | 07:46 AM
Well I understand they have different jobs with similar results. The cage ties the body together for a stiffer feel and less body twist to help keep the suspension planted, where as the sway bars help to tie the left and right side of the suspension to the frame so when one side tries to dip it pulls the other side down with it, which yields more resistance to dipping to one side..which helps keeps the tires planted more evenly and prevent major bodyroll..Im simply asking with the cage will I see a NOTICEABLE difference in performance with the sway bars added..not will the cage replace upgraded sway bars. Im going to the LSfest this summer and I may not have the cash for the sway bars after the other things required to get the car back on the road so if there is not going to be a huge difference then ill save that upgrade for later.
Old Dec 2, 2016 | 07:51 AM
UMI Sales's Avatar
Originally Posted by Project_Reaper
Hey guys, so my car has been down for 2 years now for a slew of new mods and I'm currently stuck at a fork in the road bc I don't want to waste money. The car is being built to go compete in the LSFEST grand champion event, that being said it needs to be beast at autocross. I'm currently installing a 6 point cage, the car already has SFC`s and tower brace, so my question is, with the SFC's, STB, and 6 point cage...would upgrading the front and rear sway bars even yield much difference? or would cash be better spent on new Springs or shocks?
Shocks and springs are the heart of what you are trying to accomplish!
There will probably be no bigger upgrade than shocks and springs when you are building a track car. There's an old saying that goes "you get what you pay for" that applies here probably more so than any other component you'll install on your car.
If your building a track car like you stated the sway bar upgrade would be a necessity as would most of the factory suspension.
This may not need to be done all at one time. Seat time is probably the biggest factor in the whole equation.
I think there are a few guys here that will attest we have a proven high end shock and spring package for auto-x/road race applications that will also work flawless on the street as well.
http://umiperformance.com/catalog/in...Path=7_435_439
Craig
Old Dec 2, 2016 | 07:58 AM
blackandgold's Avatar
For handling sway bars > roll cage. If you want it to be a beast at auto-x I don't know why you're even second guessing better sway bars.
Old Dec 2, 2016 | 07:59 AM
79_T/A's Avatar
You won't notice a change in handling with a roll cage. A roll cage does absolutely nothing to help the car from rolling over during cornering. A roll cage does nothing to address defencies in the stock suspension tuning.
They are two completely different things. Stiffening the chassis is never a bad thing, but if you don't change your suspension tuning you won't notice a difference in handling.
So yes, you will notice quite a dramatic difference in handling by changing sway bars. But as UMI said, they must be matched to your spring rates as a whole package.
Old Dec 2, 2016 | 08:45 AM
Craig
Oh I agree with the seat time for sure, Im by no means a pro but ive been a member of SCCA for some time now and Im pretty familiar with Autox, very fun to be relatively low speed
^oh Im not saying Ill never need them, I will eventually replace and upgrade every single aspect and part of the suspension, my goal is to have a street legal Le Mans car thats still streetable , simply wondering under this time crunch which would be the better place to spend the cash b4 this next summers event, whether it would be sway bars, springs or shocks..unfortunately I wont be able to do all 3 b4 this race..just hoping to get the best of my moneys worth that I can for this trip.
..well I have to respectfully disagree slightly with that, I already have the cage in, and I did notice an upgraded feel in the launch on the drag track as well as less chassis flex in the curves. See Im buying new rims and tires with my tax return, unfortunately that alone is going to run around $2,200 , after that im also dropping $400 on the new dyno tune since Ive done alot of engine work last summer. Sooo im not sure Ill have enough of a tax return left for sway bars AND springs or shocks..just hoping I can pick one that will help the most. I apologize if the original post made it sound as if I was split between getting a cage or sway bars,..I was asking if the sway bars would yield a major difference with the cage in, though that has been answered now, so the only question that is left is, what would yield the best results given the suspension, chassis, and tire upgrades I currently have. Sway bars, springs, or shocks?
Old Dec 2, 2016 | 08:48 AM
Craig from UMI, maybe if you can quote me a good setup with possibly a veterans discount??
Old Dec 2, 2016 | 09:53 AM
UMI Sales's Avatar
PM sent
Old Dec 2, 2016 | 10:41 AM
Sorry I missed that last sentence in your first post. The traditional progression is this: springs/shocks -> sways -> watts link -> profit
Personally I wouldn't have bothered with a cage in a stock suspension car, but to each their own.
Old Dec 2, 2016 | 02:34 PM
Well I do drag racing as well as some fairly fast top speed runs, my last TS run was 180mph+ so I prefer the safety of cage, plus it helped my 60' pretty decent. I do everything in this car so its being built slowly with a well rounded multi purpose design in mind. Btw thank you too everyone who responded, I just wanted to make sure that I was spending what little bit of cash I have in the correct and most effective spots first. So just to make sure everyone is at least relatively on the same opinion, I should try for a springs and shocks setup first to get me through this event and then sway bars later?
Old Dec 2, 2016 | 03:09 PM
You ran 180mph on a set of 15 year old shocks springs and bushings? You're a braver man than I my friend.
Old Dec 2, 2016 | 05:15 PM
That was back in 2008 ..but I was alot less intelligent back then as well. Surprisingly the car was very stable at those speeds.
Old Dec 3, 2016 | 06:43 AM
JD_AMG's Avatar
Shocks are by far the weakest link on the stock suspension. Youd be quicker by getting rid of all other mods you have now and just getting really good shocks, yes that much of a difference. You have also added considerable weight with SFCs and the cage, which will do little to nothing for your handling game, and in some instances hurt it because of the added weight on a car that doesn't flex in corners.
So you think a modern day 3400lbs steel chassis car will flex while cornering before a street tire gives out grip? Your tires will give out far before you experience anything close to flexing, they simply dont have grip to strain the chassis enough for anything.
What you are feeling is not flex, its the overly soft and very very poorly damped stock suspension moving all around, and the way the solid axle moves in comparison to the independent front suspension. Rear feels different and disconnected to the front right? Yea thats the shocks. Floatyness, unstable and unpredictable when pushing hard? You guessed it, shocks. Not all that confidence inspiring? Shocks...
If you really want a great handling machine forget about power and invest in suspension first.
While we are on the topic of auto-x or road racing, what brakes do you have? Hopefully not some drilled rotors and autozone ceramic pads...
Old Dec 3, 2016 | 06:45 AM
79_T/A's Avatar
The placebo effect is strong...
Old Dec 3, 2016 | 09:05 AM
JD_AMG....let me say this as respectfully as possible. Please stop..First- I never said I was running factory tires, you assumed this, I actually run 295 Pirrelli P-Zeros, that's why I said my new set of tires is going to be $1,400, Second- yes SFC'S DO help with handling, I shaved 2 seconds off my hourglass solo run for the SCCA with just that one mod, Third- why...why would you assume I'm running some cheap Autozone drilled rotors?..no never mind, please don't answer that.
Old Dec 3, 2016 | 09:10 AM
a very big thank you too all who have replied, after speaking to a few of you in PM and a BMW rep I'll be getting a shocks and springs combo as it seems they will do me best for this up coming event, of course I'll be grabbing a set of sway bars next year. If anyone wants to see the progress of the build or video of the event just let me know. So far it's slowly turning into a very nice well rounded racer. Funds are always the limiting factor of course.
Old Dec 3, 2016 | 09:16 AM
JD_AMG's Avatar
That still isn't enough grip to have the car flexing...
How is it that there are national title winning SCCA 4th gens running no chassis stiffening mods at all? If it gave that much of a difference all the quickest cars would be running SFCs.
Same day, same track?
When Sam strano sold his car to the new owner, the new owner ran it for a while and was doing great. He later added SFCs and his times SLOWED down, he then removed them and he was going quicker again. SFCs add weight, and do little to nothing for handling. I have 3pt welded in SFCs and they did nothing for me, n.o.t.h.i.n.g. however I have fixed the *real* problem: the factory suspension (mostly the shocks).
Because you had to ask if after adding a cage to your car if swaybars were going to be noticeable. Thats like building a forged internals LS1 and running stock cam, heads, intake and exhaust and then asking if you would notice a difference with a bigger cam, heads, intake and exhaust.
