BMR Suspension Replacement Bushings
I have BMR both swaybars, LCA, and panhard bar on my 2002 TransAm. I installed them 10 years ago. The polyurethane is dried out and falling apart. I would like to just replace the bushings, but BMR is not helping me. I see replacement bushings from Prothane and Energy Suspension but not sure if they will fit the BMR components. Does anyone know for sure what will work?
If you get the number I can check and see if they match up with the bushings we use. We sell replacements just not sure if they are the same as BMR.
I'll be at the PRI show all this week but you can give me a call at the shop next week and I can try and help you out.
Craig
Do you have the email or receipt?
You can measure the swaybars to check size, thats pretty easy.
LCAs and PHBs are pretty cheap honestly you might just have to buy new ones (and I would suggest not getting poly/poly ends on the LCAs as they can bind, you can do poly/rod end and have better performance and should ride the same). I have rotojoint LCAs from UMI and really like them, no noise (they will make noise when they need to be tightened) they articulate well and the ride is only a little more stiff from them.
EDIT: I was curious so I looked up on the wayback machine website and they have BMR's site from 2008 (nothing tracked for 2007) and its showing 32mm front, 21mm rear swaybars. So you might be able to actually use stock SS/WS6 front bushings since that was their size and some 1LE cars had 21mm rear bars so there should be bushings available for that size as well.
We have all of those bushings available directly. Just give me a call and I can set you up with them!
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
when i bought from BMR, i called them and asked for rubber bushings instead of poly. They did have them and they sent me those instead. For a street car, id much rather have rubber bushings over poly. Just give them a call and theyll help you out.
