New tie rod ends dont have castle nuts
I didn't even notice until I went to install the new tie rod end that the damn thing didn't have the hole for the cotter pin. I reused the stock castle nut not thinking about it looking for the hole. I'm pretty sure I over tourqed it. It came with a lock nut so I took off the castle nut and installed the lock nut. Kinda worried these will back out or I over tourqed it. As you can tell, I've never replaced these before..should I take apart and start over with new lock nuts and proper tq specs. I think these are one time use lock nuts.
I'm more concerned that I over tourqed the bolt. It's days 35lb and I'm sure it's way over that. Can they be too tight? Just got in a damn hurry and didn't think about it..I might new nylocks and use some blue loctite and use the tq wrench..
