02 Camaro SS Complete BMR Suspension Package???
I was considering a complete BMR suspension for my 02 Camaro SS with a Spohn Torque Arm with the tunnel brace and front drive shaft loop. I'm thinking the Spohn unit over the BMR because it is offered as one unit where the BMR unit is separate. Am I wrong, if so please correct me. Also what are the opinions out there for a complete suspension upgrade? My ride already has a Kooks long tube headers and y-pipe set up along with BMR subframe connectors. Besides that everything else is stock. Wanted input from more experience guys than myself. I plan on keeping the car for some time. Thanks guys and have a great day.
With that being said the #1 thing you need to invest in is good shocks, nothing else will make a bigger difference suspension-wise, and will make or break the setup. Do a search on here for handling setups and you can gather everyones opinions - just about every one is the same when it comes to shocks - gas charged sport shocks are the way to go. For an off the shelf shock alone koni sports (single adjustables) are basically the best you can get without going custom, the cheaper ones are more stock-like replacements but still vastly better than stock.
Springs and swaybars are generally personal preference but there are ones that are proven to work and win national championships on (strano).
Ill leave it at that for now, as I suggested try a search before buying anything as there are parts out there that hurt handling, parts you don't need and parts you do need.
I have Edelbrock shocks/struts and the struts have a coil over adapter kit it was set up this way when I bought the car. The brakes have slotted rotors. I thought the torque arm would help when I'm on the street, doing a little street racing lol. So a full length torque arm would be better for this? Thanks for the input brother.
If you have stock swaybars there is big room for improvement in handling with aftermarket ones too.
A torque arm can help if you have traction problems or wheel hop problems but will not help handling. Really you need better tires first if traction is an issue.
