AFCO rear coilover springs
The 350/125 would be more street oriented if your looking to keep some handling characteristics.
The 300/110 would be track oriented and not a great set-up if you street the car any amount of time.
If you have any questions or want to get into detail about the shocks or rates feel free to give me a call here at the shop.
Craig
A good starting point would be 300lb - 350lb front and 110lb - 125lb rear.
Craig
Craig
LS1Tech Premium Sponsor
On a high powered radial car I will go somewhere around a 125. Street cars I tend to stick around a 150 rate. A lot depends on race weight, desired ride height, and suspension geometry setup
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
If you give me a call here at the shop I can give you some specific info.
We have installed the Viking and Afco coil-overs on our 4th Gen. with all the different spring rates/Heights and gathered data such as exact ride height range with a particular spring and where the perch nut will be at that particular ride height on the shock, How close you will be to riding on the bump stops with a particular shock/spring package at all the ride heights in the range...etc
We have come to find out that some of the shocks in these kits aren't the best suited shocks when it comes to getting specific with shocks/springs/ride heights.
We did a lot of research and spent a considerable amount of time on this so that we can offer our customers what we feel is 100% The best possible coil-over combination when it comes to each individual set-up with the spring rate chosen and where the customer would like the ride height to be.
Craig
