Sway bar or Anti roll bar.. BMR
Hey, happy late 4th.. I had a quick question.. My 94' Z28 does a best of 1.50 60ft in the 1/4.. It's about 3250lbs with me in it.. I have a WS6 rear sway bar out of a late 80's Trans Am and an air bag in the right spring... I want to upgrade and remove that air bag etc. but would like to either maintain my current 60' or better it.. Which rear bar would you recommend? The SB003 or the XSB002? Car is street/strip
LS1Tech Premium Sponsor
The SB003 is designed as an upgraded bar for handling and street performance. The XSB001/XSB002 is a streetable anti-roll bar. Lever arm style bars are very rigid and allow no articulation for street driving and will cause bind. Our bars allow just enough for smooth movement while still keeping the car flat well into the 1.1x 60' range
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
A true Anti-roll bar will be solid mounted and have zero give to perform properly. As well as the Midwest Chassis ARB you will not have issues with the bar hitting the shocks when turning left or right as it allows zero side to side movement.
Though keep in mind an ARB does not improve 60' it is only a tool to allow consistent 60's times by keeping the vehicle level as twisting is wasted energy. Our ARB has two different chassis mounting options. A weld in tab which we always prefer and a bolt on chassis bracket plus includes adjustable links for adjustment. If your housing does not have swaybar bracket mounts on it already we do offer those also.
Any questions feel free to ask.
Midwest Chassis ARB
Midwest Chassis ARB
Please understand also, stock style bars are heavy as ****, though I will say they likely work fine. But if I can get a bar that saves 10 pounds or one that gains 5, it's a no brainer.
Right my WS6 bar is heavy af.. But I think the MWC and the BMR is a hollow design right?
"stock style bar", like if it looks like a stock bar (bent metal design) its heavy no matter what. If it looks like mine above (straight pipe), its lightweight.
Like mentioning in the PM, if an ARB can move side to side, have mounting brackets that may move, or soft mounts there is a possibility of it not holding its intended settings. They should be rigid allowing zero movement anywhere.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Sorry I didnt weigh them, and I admit that. But there is no denying stock style bars are heaviest. I know its only a few pounds but it all adds up eventually (if you want to trim weight).
I'd still be interested to hear and actual weight of a lever arm style bar. But a weight saving of 10lbs as often advertised is just not physically possible as I have shown. Unless it weighs less that zero? lol
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Well if we are going to discuss just the weight of the bar itself with nothing else then it weighs what a pound? However if you are talking every piece to bolt it on the vehicle including links, arms, mounting brackets, all needed hardware, and powder coated you are still talking less than 11 pounds fully loaded ready to bolt in.
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
1LE cars got the larger rear bar. My apologies
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
