Light in front end
Old 08-16-2017, 04:03 PM
buckeyebird's Avatar
Default Light in front end
Have not really messed with suspension yet. But when my bird gets up to 90+ on hard Accel, the front is too light. I feel like I'm going to lose control. I'm assuming I pry need some stiffer rear shocks, or complete suspension upgrade. Can others confirm. Is this a aero problem when getting up to higher speeds. What is a good next step with stock suspension. I have 430 hp, 390tq and it feels like the front is just coming off the ground.
Old 08-16-2017, 08:11 PM
stp001's Avatar
Having a car that can pull the wheels off the ground at 90 can't be a bad thing!
Old 08-17-2017, 09:02 PM
Not pulling wheels off ground. Just really light in the steering. Makes it feel darty. They are new tires too. Bout 2k miles on them
Old 08-17-2017, 10:43 PM
stp001's Avatar
I was just messin' with you, I knew what you meant. I would check alignment. Probably a little too much toe out or lack of caster.
Old 08-17-2017, 10:59 PM
Yea. Pry should start there.
Old 08-18-2017, 09:19 AM
leadfoot4's Avatar
I agree.......
Old 08-18-2017, 11:52 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Sounds like your alignment may need some work. Also check bushings in the front end. Old, worn rubber bushings will allow the control arms to deflect under high speed load and change your alignment as well. Also, be sure to check your toe rods, they are prone to getting loose and causing these types of issues
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Quick Reply: Light in front end
