F Body tunnel mount hardware size?
Hey guys,
Just curious if anyone knows the bolt size and thread pitch for the 4 bolts that you'd attach a tunnel mounted torque arm crossmember or drive shaft safety loop to? I removed the stock cross member to make clearance for my true duals and now have no clue where that hardware went. Figured someone may know off the top of their head and be able to tell me before I dump out my bucket of random bolts and start trying them, and then proceed to throw them around the garage until I can find one that fits. Thanks in advance.
I may be wrong but I'm thinking they are 14mmX1.5mm
Definitely metric tough.
Good luck, I had a hell of a time getting my Tq arm to clear the exhaust and to line up with the holes. Had to use some strong persuasion skills both verbally and physically lol.
Ok great! Thanks a lot... Yea I am going to be installing my new s60 tomorrow and/or Monday, for now I am going to TRY to keep my QA1 trans mounted torque arm as is and install the Midwest Chassis tunnel mounted driveshaft safety loop that I got, and hope to god it all clears my TSP exhaust and that the QA1 arm fits the s60 without a ton of modification... If it doesn't, well then I guess Midwest Chassis tunnel mount torque arm with the true dual crossmember gets ordered and I sell the safety loop since that crossmember has one built in. Thanks again for the help.
yep, 8mmx1.25 20mm
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
30mm is what we include with our aftermarket arms due to the added thickness of the bracket. The stock bolt I believe is 20mm or close to it. If you go with too long of a bolt, it will bottom out against the floor pan and not tighten down correctly. 20mm should be plenty of length for full thread engagement through the brace and not bottoming out into the floor
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
^^^ length isn't critical,a 20-25 long will do. I've got SLP subframe connectors and driveshaft loop tied into those points also so I used longer bolts. Also used SS bolts as things tend to corrode here in the rustbelt.
