Where to purchase wheel spacer?
I have an event coming up and I'd like to add on 18mm spacers before then. Does anyone know where I can purchase a pair? I checked out Motorsport-tech but the time is up to 2 weeks and I'm a bit bothered at paying $25 for ground shipping for something this small.
Thanks
Thanks
Ebay has quite a few to choose from. Get hubcentric spacers. You might consider getting 1 inch, as that is a dimension that they start start using a duel lug design. At 1 inch, you will probably have to grind down existing studs if your wheels have a flat flange. No big deal though.
http://www.ebay.com/itm/4X-20mm-5x4-...lZmm7F&vxp=mtr
i have these.
Pressed out the studs on the spacers.
Put ARP extended studs on the actual car and just used the spacer portion. Works great
i have these.
