mystery vibration starting at 65 mph and up.
need help with a fading in and out vibration in the front end. it comes in for 5 seconds and then fades out and comes right back. have rebalanced and forcematched tires. it is also causing the headlighs to bounce around up and down as well. any input on this would be greatly appreciated!![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Moderator
Received 1,838 Likes
I had that one time about 20 years ago. It was a front wheel drive. I tried all kinds of **** and it turned out the front tires were mismatched on size. One was slightly bigger than the other. In your case I'd verify the back tires
Check your thrust angle by measuring from wheel to wheel on each side. My 98 had a funky vibration in the frt and it was the thrust angle causing it. There was over 1/2 inch difference side to side. I used the caster adjustment to get it under a 1/4 inch and the vibration was gone.
