Afco Install
Old Sep 9, 2017 | 09:08 AM
Greekey's Avatar
Default Afco Install
I'm in the process of installing afcos on all four corners. I noticed that this shock doesn't sit or take up all the space in these mounts. Is this normal!?
Old Sep 9, 2017 | 11:12 AM
2ToeRacing's Avatar
Let's hear more about these shocks.
Old Sep 9, 2017 | 03:39 PM
Darth_V8r's Avatar
Moderator
My kit shipped with spacers to address that issue
Old Sep 9, 2017 | 04:25 PM
Greekey's Avatar
Can you just please find me a picture or a part number?
Old Sep 9, 2017 | 04:36 PM
Darth_V8r's Avatar
Moderator
It'll have to wait on both. I'm not home. But it's basically a 1/8" spacer on each side. You could get that at lowes
Old Sep 9, 2017 | 08:00 PM
Greekey's Avatar
Thank you
Old Sep 10, 2017 | 01:15 PM
Greekey's Avatar
Well I bought some hardened washers! I hope it is sufficient!
Old Sep 10, 2017 | 02:16 PM
2ToeRacing's Avatar
are those shock double adjustable??
Old Sep 10, 2017 | 02:28 PM
Greekey's Avatar
Yes they are
Old Sep 10, 2017 | 05:03 PM
Chrisingermany's Avatar
I hope that pic above isn't how you are installing them.
Old Sep 10, 2017 | 05:22 PM
Greekey's Avatar
Please explain! Umi told me it was fine this way.
Old Sep 10, 2017 | 05:58 PM
Greekey's Avatar
If you're talking about the rubber piece and what not, I have since figured it was incorrect in this picture!
Old Sep 10, 2017 | 08:53 PM
Greekey's Avatar
Old Sep 11, 2017 | 09:18 AM
Yeah, now it looks correct.
Old Sep 11, 2017 | 10:17 AM
MidwestChassis2's Avatar
It appears you purchased shocks with a 1" bearing and your mounts are for a wider bearing. Afco, Strange, Viking, Qa1 all make a wider bearing but 1" bearing with 1/2 hole is standard for a coilover shock and what all our mounts are set up for unless a customer request a different width.
Old Sep 11, 2017 | 10:19 AM
Greekey's Avatar
These are Umi mounts. I was told that Umi makes them this way to be able to fit multiple bearing widths. They told me washers would work just fine.
Old Sep 11, 2017 | 04:02 PM
2ToeRacing's Avatar
Are these drag shocks?
