Easier ABS Delete?
Old Sep 18, 2017 | 11:35 AM
1bdbrd's Avatar
Default Easier ABS Delete?
Has anyone else used this Wilwood proportioning valve for their abs delete? I saw one person use it and did a search and it has been asked about a couple other times but no real answer. I could do the SJM kit but I don't want or need a line lock and I used that kit on an old car of mine and hated it.
https://www.summitracing.com/parts/wil-260-11179
Old Sep 18, 2017 | 02:37 PM
The Batman's Avatar
My sjm kit came with a different one. Fwiw, You can order the sjm kit designed without a line lock if you wanted.
Old Sep 18, 2017 | 05:48 PM
1bdbrd's Avatar
I don't like the SJM kits because I could never get my old one to seal no matter how many times I tried. After buying that kit I never liked the setup so I would stick with a non-functional ABS block before I tried that setup again.
Old Sep 19, 2017 | 09:58 AM
biketopia's Avatar
I used a summit (wilwood) valve for my ABS delete. Post 18 https://ls1tech.com/forums/suspensio...l#post19706606
Granted I have only have a 3 channel system but 01ssreda4 did a delete on his 4ch system with the same valve. https://ls1tech.com/forums/suspensio...bs-delete.html
I ran all new lines and from the MC to the valve and line lock I went ahead and installed, then added a tee for the front's. The fittings are metric in the MC, 3/16 line will work, just need to bubble flair them if you go that route, then good ol' double flair into adapter fittings on the valve.
Old Sep 19, 2017 | 10:26 AM
01ssreda4's Avatar
I used SJM and just didnt wire up the linelock.
Old Sep 19, 2017 | 04:20 PM
1bdbrd's Avatar
My big hangup with SJM is cutting the stock lines always felt like a hack job to me. With the block I linked above it looks like I can remove the lines from the abs block and install the prop valve using the stock lines instead.
Old Sep 19, 2017 | 06:34 PM
biketopia's Avatar
That would probably work out just fine. You will probably need to re flair the stock lines to double flair and get the appropriate fitting, but a 3/16 fitting will fit on the line.
Old Oct 9, 2017 | 07:08 PM
Vexzer's Avatar
look here. https://ls1tech.com/forums/suspensio...l#post19742918
 Michael S. Palmer
