Stripped/seized brake fitting
Old Sep 27, 2017 | 07:47 AM
Greekey's Avatar
Default Stripped/seized brake fitting
Hello guys! In the process of removing my rear for a 9”! I went to take this brake lines off and the bottom one is seized and now rounded off! Yes I used the correct wrenches and pb blaster, it will not budge! Any input?
Old Sep 27, 2017 | 08:06 AM
Red_Zone's Avatar
channel locks?
dremmel the rounded edge down flat on 2 opposing sides to get better grip...
Old Sep 27, 2017 | 05:19 PM
Captain Slow's Avatar
I had the same problem with that flare nut. This tool made it, it's bitch.
IRWIN Tools VISE-GRIP Locking Wrench with Wire Cutter (4)
Amazon Amazon
Old Sep 27, 2017 | 05:21 PM
Greekey's Avatar
IRWIN Tools VISE-GRIP Locking Wrench with Wire Cutter (4) https://www.amazon.com/dp/B00004SBBD..._ZncZzbBSRE3NK
Little too late! Ended up twisting brake line into a pretzel! Yeah, I’m about screwed! This line goes all the way to the front! Fml
Old Sep 27, 2017 | 05:23 PM
I see this in your future..
Old Sep 27, 2017 | 05:27 PM
Greekey's Avatar
I sure do too! What type of flare is this? Bubble flare!? And by any chance do you know what size flare nut?
Old Sep 27, 2017 | 05:29 PM
Greekey's Avatar
I would literally pay someone to make one for me! Haha
Old Sep 27, 2017 | 06:26 PM
It's a bubble flare. I can't tell you what size it is till I get back home tomorrow. Napa had them in stock. It's easy, though.
Old Sep 27, 2017 | 06:30 PM
Greekey's Avatar
What did you do for the braided section right before the abs block?
Old Sep 27, 2017 | 06:54 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
No need to run a new line all the way to the front. Cut it somewhere where you would have access room to use a flaring/bubble tool(as in above pic) and use a union.
When we(at Tuffy) encounter a 'rounded' tube nut,we cut the line(with good wire cutters) at the tube nut and either force a 6pt socket on it or use an 'extracter' socket. Then use a union to replace only a section of line.
Brake line is 3/16". Metric thread is 10mmx1.0 thread size and is used for bubble flare and double flare. US/SAE thread is 3/8-24 and is used for bubble flare and double flare.
Unions are available for all four situations.
Metric 10mmx1.0 and US/SAE 3/8-24 are visually similar but not interchangeable. I always have a 10mmx1.0 bolt & nut and a 3/8-24 bolt & nut handy to identify which I'm working with.
Old Sep 29, 2017 | 08:53 PM
Greekey's Avatar
Do you guys think this will be okay!? I ran a piece of new brake line using a union but I made the line a little short! Bottom line was supppse to be on the bracket below the other line!
Old Sep 30, 2017 | 06:20 AM
NO,the up & down movement of the rear end in normal suspension travel will break the line still in the bracket at its' fitting in the bracket. It's not a lot of movement,but eventually it'll break. Just like taking a piece of metal and bending it back and forth until it breaks. If you're gonna drive it for a while,put a couple of the tie-wraps from that line to the hole in the bracket to limit its' downward movement.
Old Sep 30, 2017 | 08:32 PM
Greekey's Avatar
First time flaring a brake line! How does it look overall?
Old Oct 1, 2017 | 06:34 AM
For the first time,nice. Glad I don't have pics from my first time ! Even though that'll work perfectly,could be larger as in post #5,but if it seals,go with it as it won't pull out.
Old Oct 1, 2017 | 08:47 AM
JOHNNY59's Avatar
Bubble flare should not be used for steel brake line tubing! Use a double flare and the correct union.
Old Oct 1, 2017 | 10:46 AM
^^^ ??? Our cars(my 98Z) came with steel brake line with bubble flare.
The OEM line from Master to ABS block is steel with bubble flare w/M10x1.0 fitting at the ABS block.
The SLP line-lok kit came with steel lines with bubble flares.
Old Oct 1, 2017 | 11:15 AM
Greekey's Avatar
He may be talking about using bubble flare with a union! Idk
Old Oct 1, 2017 | 12:22 PM
Bubble unions are available in both versions,metric M10x1.0 and US/SAE 3/8-24. We use both at Tuffy.
Old Oct 1, 2017 | 09:45 PM
Greekey's Avatar
Well it ain’t perfect but perfect enough for me ‘
Old Oct 2, 2017 | 06:15 AM
Looks good !!!
What brand tool did you use for bubble flaring ?
