Sway bar hitting Moser 12 bolt
Put some spacers between the "flats" of the axle mount and the "flats" of the bushing. Hence lowering the rear of the bar. Moving the bar rearward will require fabricating some special axle attachment brackets.
LS1Tech Premium Sponsor
^ this is a simple and effective solution. A shorter end link may also be used to rotate the bar some and gain clearance.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
