No ASR dash light cannot turn ASR off
2001 Camaro SS
No asr light when key goes on, switch on dash does not turn off asr. I took it to a garage and asked them to check codes. They said it was showing a bad electronic brake control module and that was the reason I can not disable asr, However I get no abs lights or any indication of abs not working but I do have a check engine light showing a misfire across all cylinders but car runs strong and idles smooth. The only thing I have not tried is to lock up the brakes to check the ABS
Can I have a bad ebcm without any warning lights?
