Moog front springs?
Moog front springs?
Looking for feedback on Moog 60114 and 60116.
Spohn sells the 60116 and touts them as "SS" springs.
Any application catalog lookup indicates 60114.
What have you used and what's your feedback?
Thanks,
Charlie
Thanks,
Charlie
I was looking at both of these last year when redoing my shocks. I got the Moog 60114 springs just as a stock replacement on my 2000 TA. The length is exactly the same as my stock springs, the coil diameter was the same or nearly the same also. They seem to work just fine.
If I remember right, after a bunch of reading the "SS" springs are just slightly longer than the stockers, though I'm not sure about the actual spring rate. That said the stock springs/60114's are already quite a MF'er to compress already and get aligned on the shock. To compress my springs enough for the shock I had to compress the spring till the coils were near binding on each other. My guess would be the "SS" springs are even harder to install since they're an even tighter fit on the shock.
