Setup Opinions
Founder's STB
Founder's lower control arm extreme joint
Founder's adjustable panhard bar/relocation kit
Founder's adjustable torque arm
Founder's relocation brackets
Hawks Sinister weld in subframe connectors
Strano lowering springs
Strano sway bars
Koni Str.t shocks/struts
Monroe 904962
Upper strut mounts
Russell stainless brake hoses
UMI bump stops
You can buy a relocation bracket from UMI (http://umiperformance.com/catalog/in...oducts_id=1036) or you can make your own if you have a welder. I made my own and restored it's intended angle. I went a little less than 4". It's sitting at 2° now but I'll be raising the rear 1/2" or so anyway.
*edit - I see the product you are talking about. That is an incomplete kit for one, purpose being only to make room for exhaust is stupid by itself because it negatively affects suspension. When lowered properly (on BOTH sides) it is good for handling and room for exhaust is just a bonus. Plus that bent support bar should be straight.
Here's mine, Unbalanced Engineering relo kit with their panhard. I made the support bar with DOM and the exhaust is single 3.5". I could have gone lower with the support mount if I needed more room.
Founder's STB
Strano sway bars
Monroe 904962
Upper strut mounts
UMI bump stops
Maybe more important is we can discuss what to do and why. If you relocated the PHB you want to do both sides lest it end up crooked which makes the asymmetry of a PHB even worse. I would go with a different brand brake like kit, probably Goodridge, but I sell Russell too. I'd recommend a Master Cylinder brace for sure, which should work with a Founders STB should you go that way given it's, similarity. to the UMI.
And on a K which seems to be down the road, there is no way I'd do any single cross tube K, let alone one that doesn't have the ability to lock the camber and caster from sliding. I.E. I think there is only one choice here for sure.
