5th Gen Camaro IRS
5th Gen Camaro IRS
I was wondering if there is anyone here who has tried and/or succeeded in fitting the IRS off of a 5th gen into their 4th gen. The 5th gen's rear end would offer more power handling, better ride, better handling, better weight management, and a number of other benefits on top of low initial/parts cost.
It doesn't look like it would be all that difficult to set up versus the C4 IRS or the Heidts system. Due to the newer design, not to mention the parts availability, it would likely be a good candidate for a pro-touring style build. Has anyone tried this, or seen any examples of cars with this retrofitted?
I can see why when after you price out an IRS from a 5th gen or 6th gen, then cut and hack the car up enough for it to fit (if it even will fit), you might as well just buy a C5 by the time you have spent all the time and money to get it to work right.
I don't see where the extra 6 or 7 grand is coming into play on this. A used 5th gen rear can be had for as little as under a grand, and if you can fabricate on your own, I don't see much more cost other than maybe new coilovers, which even if you go custom wouldn't be more than $3k. And if you get an lt1 car, the price difference is even greater.
Factor in the savings on an aftermarket rear, and the price of a Corvette gets farther and farther away.
Originally Posted by mikedamageinc
Even if you get a free irs, the point is that you will spend a month straight in the garage installing and working out bugs. Most people don't have that kind of spare time
The following users liked this post:
Bob's camaro (01-11-2024)
