Name that ...brake squeak or squeal I have. audio clips provided !
This is the noise the squeal I am getting from what seems like the rear passenger side wheel when I hit the brakes after driving the car for about a minute or so. Doesn't do it immediately it takes a little bit of time but no more than a minute or two. The higher pitch means I'm hitting the brakes even after I let off it still makes the noise and as you can hear when I slow down so does the sound it slows with the rotation of the tire. car has new rear axles new rotors new brake pads and a new emergency brake. Mechanic is kind of stumped is thinking it's either the backing plates or a stuck caliper? PLEASE help me.
I have heard similar before. In the past it has either been either a sticky caliper, or some inconsistency in the pad material or rotor that scrapes on rotation. I would put it on a lift (or jack stands) and see if you can get the sound by spinning by hand, you may be able to feel some resistance when the sound is made to help identify the source. I would do this starting with the wheel on still to rule that out as a cause.
I also have a secondary guess from an old buddy who's a mechanic but a good distance away who listened to the clip and said it sounds like a backing plate. Anyone else? I'm open to all suggestions and guesses.
I would take apart the brakes and lube everything real good. caliper slides, pad ears, back of pads, caliper piston cup. make sure the pads move freely in the caliper bracket and the clips are snapped in correctly. also make sure the rotor is not warped and the wheel bearing has no play.
So. Temps at night when I leave for work have dropped lately down into the 50s. Didn't squeal much during the winter months. This past week? Nothing. Only other thing different was I sprayed the house all throughout the wheels brakes etc hoping maybe it was some loose dirt or something lodged in there. A good hosing and cooler temps and it is silent again. Can't wait to see if it comes back when hot..
