Brake Pedal Feel
Save the manuals!
I believe that in comparing sliding caliper brakes and fixed, you need to multiply the surface area of the stock sliding caliper pistons x2. The reason being, is the fixed caliper will only move the piston side, but the floating caliper will move the piston, and it will move the cylinder itself, sliding the entire caliper in the opposite direction to engage the opposing pad on the outside of the rotor.
^ For the purposes of figuring out if the brake booster is sized for the calipers, this extra math isn't needed. One can simply look at the proportional difference in the surface areas of the pistons before and after. (This deals with total force applied, and being put out by the brake booster, and just doesn't divide it up between front/back and the sides of the rotor.)
One would take the force at the brake caliper piston and divide it by 2 in order to figure for the pad force on each side of the rotor, but... the forces would also have to be divide proportionally (first) between the front and rear because the pistons on those calipers are different sizes.
My thought is, in this following basic example, assume all pistons are 1" diameter for master and all calipers to keep numbers simple. You press the brake pedal to move the master 12" (1x12). Sent to the fixed 6-piston, each piston will move 2" (12/6 = 2"). If you send the same fluid to the floating caliper, assume the brake rotor is 3" away from the pads. The pads will push on one side until it hits the rotor, then the other side will begin to move, since the caliper can slide. The pads will then extend out another 3" from the other side from the same fluid continuing to flow into the same 2 cylinders. So each pad will move 3", or put another way, the piston will move 3", and the caliper will move in the opposite direction by 3" (12/2 = 6, and 6/2 = 3"). If it were a 2-piston fixed caliper, then each pad would move out by 6" (12/2 = 6").
Save the manuals!
Since my rear brakes are the stock units, I don't think this enters into it, unless the fronts are confirmed to be of a different surface area, which would indicate an introduced imbalance front-to-rear. But going back to the fronts, I am not sure what you are saying exactly. In the first paragraph, it seems as if you are agreeing with what I stated, but then in the second I am not sure. Are you saying that you would then compare 3 pistons (half the 6-piston caliper) to 2 pistons on the floating caliper?
You can use hydraulic formulas to calculate piston movement, but that doesn't help what you want to know. You are interested in the situation where the pistons have completed their movement and the pads are all touching the rotors. At that point, your booster is developing pressure (PSI) and you just want to see how that pressure (PSI) is divided up among the total surface area of all the pistons the booster services. If the new total surface area of the pistons is greater than stock, then the pressure will be divided up across a wider area, resulting in less braking force. In order to make up for that, the booster will need to create more pressure - which will be delivered by your foot.
The rear brakes are significant because they take proportional amount of force from the booster. Mathematically, they are almost like a "shock absorber" for this problem. The smaller they are in relation to the front caliper pistons, the greater you should feel the difference in the change of front calipers.
PS: Sorry to OP for thread-jacking this brake problem request for help.
Save the manuals!
Stock - Scenario A:
Fronts - 1.5 sq in.
Rears - 1 sq in.
Aftermarket - Scenario A:
Fronts - 2 sq in.
Rears - 1 sq in.
Stock Surface Area - Scenario A= 5
Aftermarket Surface Area - Scenario A= 6
Percentage increase = 20%
Stock - Scenario B:
Fronts - 1.5 sq in.
Rears - 1.25 sq in.
Aftermarket - Scenario B:
Fronts - 2 sq in.
Rears - 1.25 sq in.
Stock Surface Area - Scenario A= 5.5
Aftermarket Surface Area - Scenario A= 6.5
Percentage increase = 18%
