From drag to corner carving
So my car has weld drag ligjts and slinmies.in front..gonna replace wheels in spring...eventually do konis.....now my questions is....I have a spohn drag rear sway bar out back...can I add a front tubular one to balance it out or do I have to buy a matching pair
Do you have the specs for the bar you have in the rear? As you attempt to determine what you have and how that would match up with what's available in the aftermarket, here's a breakdown from Strano's website on the stock front/rear bars compared to his:
Front bar comparison:
GM 30mm: Approximately 243 lbs/in
GM 32mm: Approximately 351 lbs/in
Strano 35mm hollow: Approximately 487 lbs/in
Rear bar comparison:
GM 19mm: Approximately 128 lbs/in
GM 21mm: Approximately 189 lbs/in
Strano Performance 22mm hollow: Approximately 228 lbs/in
For what it's worth, I ended up going with Strano's matched pair of hollow bars with the adjustable rear and I absolutely love them. Most will tell you to run a square wheel setup on all four, however I have a few sets of wheels I run. One of which is a set of staggered OEM C5 Z06 Speedlines, so it's nice to have the flexibility to make adjustments to the rear.
- not sure what the size is...installed it like 8 years ago....might just go with stranos.matching pair....just thought it he easier if I could just get a front one to offset it
OK so found out on YouTube that the spohm rear anti roll drag bar is 1inch 5/16 in diameter..so Def won't flex but was wondering what size for front to best compliment this should I make turns
there aren't any front sway bars available for these cars that will be big enough to compliment that size rear bar, the 35mm strano bar is a fraction of an inch bigger and you will end up with sporadic over steer because of that. you'll be best to cut your losses and sell that spohn bar and start over with new ones that compliment each other correctly
pretty much what pewterSS said above lol
