Best OEM sized rotors?
I have a Baer Eardispeed rotors on all 4 corners that I got used a long time ago. Lately, the car has been feeling like the rotors are warped. I noticed that Baer does not make Eradispeed rotors for the rears anymore, so looking for suggestions.
Stock calipers.
Stock calipers.
stick with the hawks. great value to overall brake quality ratio. best advice i can give, which i will get backlash for, is just stick with a blank rotor, or at the most just slotted.....dont get drilled. but i assume you will do your research and decide which is best for you. here are the rears i would recommend, summit has the rears you would have to search for the fronts i guess
2000 CHEVROLET CAMARO Centric Parts 125.62065 Centric Premium High-Carbon Brake Rotors | Summit Racing
The following 3 users liked this post by Floorman279:
The following users liked this post:
ramairjohn2000 (01-11-2021)
1bdbrd (04-20-2021)
drilled/slotted increase braking performance and longevity by cooling faster and getting brake dust and gases away from the pad faster.
Front Eradispeed Rotors:
Front EradiSpeed+ High Performance Rotor Upgrade for GM F-Body 2301006 - Baer Brakes
Rear Eradispeed Brake Rotors and Calipers:
1993-2002 F-Body Rear Systems - Baer Brakes
.......and I don;t think there's another OEM size aftermarket brake rotor thats anywhere as good as Baer Eradispeeds. Mine, all 4......18 years old and still have plenty of life left.
The thought that holes drilled in rotors lessens the stopping power is simply not true. And if it is.......its unmeasurable. Impossible to measure. Especially for a street car.....its 100% meaningless. Tires stop cars, not brakes....if you're talking about hardcore stopping power. Cooler brakes last longer, holes allows better cooling and gsater cool down after a hard stop. In the old days they drilled holes to allow gasses to escape from the older days crappy pad material. Multi 100 thousand $$$ and multi million exotics use cross drilled rotors. Yes, they look good.....but they also stop just the same as non-drilled rotors. The surface area added up from all the holes is an amount thats unmeasurable in stopping distance.
I also want to replace my old Erads....... I was thinking of the new Baer Erad Front and Rear complete brake kits. But....expensive. But they are probably amazing performers. Definitely outperform any street tire by a long way.....
You will get zero benefit from drilling on the rear of these cars, drilling is to dissipate heat, if you ever get the rear hot enough to need that feature on a 3-link solid axle car you have already lost the front which is to say 80% of your braking capacity, I got my rears slotted mostly just to match my slotted fronts, for the record I wouldn't run any drilled rotor on the street for several reasons but a big one is that cracking is a real issue with drilled rotors.
