Suspension help
Old Mar 1, 2021 | 06:38 PM
Michael Washington's Avatar
Default Suspension help
Hello guys! I’m looking for some help getting this car to hook! Struggled all last season on radials. I made the switch to a 28x10.5 slick this year and still having trouble. I think I may be hitting the tire a little too hard. I know the tire psi is a little low in this video, but regardless of where I had it it did the same thing. Antisquat value of 111% ic 42 inches. Any help would be appreciated.
File Type: mov
Old Mar 2, 2021 | 04:30 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
What transmission and rear shock do you have in this car?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Mar 2, 2021 | 06:18 PM
It has a 4l80e with Viking double adjustable coil overs. Leaving on a transbrake.
Old Mar 3, 2021 | 12:50 PM
BMR Sales2's Avatar
I would tighten up the front shocks, and add some air to the tires. Where are the rear shocks set at now?
__________________
Glenn ***
Sales Tech
813.986.9302
Old Mar 3, 2021 | 02:44 PM
Out of 19 clicks of adjustment the rears were at 10 compression, 10 rebound. I increased rebound by 2 clicks each pass maybe up to about 14 before the day was over with not much change. I am considering switching my 110 springs to a set of 125s that I have to slow down the hit a little, and see if it helps.
Old Mar 3, 2021 | 04:55 PM
BMR Sales2's Avatar
the 125 should help you. What strut and spring is in the front. If you want quicker help you can give me a call.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Mar 3, 2021 | 08:11 PM
Yes that would be great! How do I contact you?
Old Mar 3, 2021 | 08:29 PM
Boostedrooster's Avatar
I installed Viking double adjustable front and rear I had to soften compression all the way down in the rear and soften rebound all the way in the front. I couldn’t beleive I had to max them out but after a few test passes it’s what it took and dead hooked once I did
Old Mar 4, 2021 | 05:54 AM
That is pretty wild. What kind of rebound settings did you end up with in the rear?
Old Mar 4, 2021 | 09:10 AM
Rebound was set at 8 clicks in the rear turning it from the minus to the plus pretty much right in the middle. And I kept compression at 6 clicks in the front turning it from the minus to the plus. But it seemed to work for me i have to max mine out to get the weight transfer to hook I think bc I don’t make enough power with the gearing I have in the car to get the weight to transfer on its own.
Old Mar 4, 2021 | 10:47 AM
BMR Sales2's Avatar
Call me at BMR 813-986-9302
__________________
Glenn ***
Sales Tech
813.986.9302
Old Mar 18, 2021 | 03:24 PM
Black_Sunshine_99's Avatar
Can you share some deets on you combo?
Engine, trans, t-brake, gear ratio, rear tire size, power level, rpm on leave, vehicle weight?
I just picked up a big turbo camaro w/ Viking DA on all four corners and intend to hit the track this season so a baseline would be great.
