02 camaro suspension
So I recently swapped my 02 camaro ls1 engine (cause it blew up) for a 5.3 lm7 it’s an iron block so the car sits lower in the front I want the camaro to be a daily and I plan on putting a lsa supercharger later what kind of suspension do y’all recommend anything helps thanks.
https://www.texas-speed.com/p-5886-v...02-f-body.aspx
These with the 300lb spring have worked well in my 01 but you may opt for the 350lb spring.
