Best Rack & pinion ???
Like the title says
Replacing the rack in my 97 Z that has a LS swap, so it has a LS1 K-member and rack
Trying to figure out which one to buy
From what I've read, there are at least 3 different LS rack & pinion units for the F-body
There's one that doesn't have a code with it (base model maybe)
The FE2, FE4 and FE7 unit
And the F41 unit
I guess they all interchange (never heard of a different LS k-member for a different rack)
Thanks,
Rob
And the F41 unit
Thanks,
Rob
Save the manuals!
Here's a good thread on finding the match: https://ls1tech.com/forums/suspensio...ck-pinion.html
The three AC Delco Parts:
- F41 suspension
~ One part number in the "Gold" product line
- (FE2, FE4, or FE7) suspension
~ One part number in the "OE" product line
So I'm putting a LS motor in my 97 LT1 car
So I won't have the correct data on my car
With that said Is one of these racks for better performance handling then the others
Just doesn't make sense that they call them different things (FE2 FE4 FE7 and F41) and they are all the exact same thing
Thanks,
Rob
Thanks,
Rob
They're all the exact same looking rack-n-pinion but the F41 is the stiffer performance suspension handling one. Why not rebuild the one you already have?
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/220x165/20200822_174321_1__5a3d6f6a3db9f622000923bf84e5dd04acedde75.jpg)
Yeah the V6 and V8 racks are not the same and you could very easily be sent the wrong one.
Save the manuals!
BTW - When you assemble everything, you'll want to put the bolts in from the bottom and use locking nuts at the top. (Unlike the way the cars were assembled from the factory.) This will help you change the rack with the engine in the car, if you ever need to in the future: https://ls1tech.com/forums/suspensio...-bolt-wtf.html
The following users liked this post:
ddnspider (01-14-2022)
