Popping noise from front suspension when driving
I just re did all of the front suspension on my camaro, I also did Koni shocks paired with bmr lowering springs. After driving about 50miles it randomly got a noise up front. It’s like a popping noise, not quite a clunk. It gets more rapid as you’re going faster. Right before it happened I was on the interstate and hit a decent sized bump. I don’t believe it gets louder when hitting bumps. It also has new SKF wheel huh assembly’s. I didn’t have time to get it up on a lift to check everything over yet. For the record I did not get it aligned yet. The toe is fine but the caster is off a little. I’m getting it aligned tomorrow. Any input would be appreciated because I can’t think of much.
Yea I believe so, I’ll put it up on a lift tomorrow and double check everything and do an alignment. Im also going to check u joints. There the original with 90k miles on them. Coming back from work now and it sounds like it’s maybe coming from the driveshaft.
yea I’ll definitely post what it is. It’s more of a thumping noise. I have a feeling it’s the front suspension because that’s all I touched and it didn’t do it before. Although it could really be anything.
Well I figured out what it was. Somehow I overlooked the lug nuts and they backed out a little. I ran them down with the impact and completely forgot to torque them. Luckily I caught it before the wheel fell off. I guess I’ll never forget that now
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
