Recommended bushings for 99 Camaro
Hey!
I have a 99 Camaro LS1 6speed manual which I have next to no service info on. The car has done 176'000 kilometers, which would be about 110'000 miles.
I figured I should do bushings when fall comes, and as I live in Norway, I should buy them within a month or so to be sure that I get them from US in due time.
There are many bushings and other items which may be changed in the suspension to make the car fresh, but from what I gather these are the bushings that we have (please correct me if there's more):
Front:
Front control arm. (Is there an upper and lower?)
Stabilizer/Sway bar bushing.
Rack and pinion bushing
Tie rod ends (only on outer I believe)
Rear:
Lower control arm.
Track Bar/Panhard Bar.
Bump stops.
Other:
1 transmission mount.
Motor mount front left and front right.
Are any of these worth buying polyurethane? I'm looking for a daily driver kind of thing, it will see minimum to no track usage.
Also, is it worth buying LCA which are tubular and with polyurethane?
Front:
Rear:
Lower control arm.
Bump stops.
Other:
Pontiacerator
I went through almost all of mine a couple of years ago at abour 175k. Here is what I remember:
Front control arms: I did lowers with Moog bushings. Not much rides on the uppers.
Stabilizer/Sway bar bushing: Urethane is good here, for the end links as well.
Rack and pinion bushing: Did not do.
Tie rod ends (only on outer I believe). Mine were and continue to be fine at 197k
Rear:
Lower control arms: Moog "ILE" bushings
Stabilizer/Sway bar bushings: Urethane again here and on end links
Track Bar/Panhard Bar: Don't recall if I replaced those. Don't think so.
Bump stops: Mine are original.
Other:
1 transmission mount: Factory style rubber. Urethane will transmit vibrations.
Motor mount front left and front right: Definitely urethane. They transmitted vibrations for about a month and then settled in. Once they're installed, you'll never have to replace them again.
Rear:
Other:
The following users liked this post:
Redsent (06-25-2022)
Pontiacerator
Like original. I had some clunking noises that were cured by replacing the sway bar bushings. My worn out motor mounts caused a grinding sound at idle. That was cured with the urethane mounts. As I said, those produced vibrations for the first month or two of driving, but that went away and it feels like stock now.
One thing I forgot to mention was ball joints. I replaced those as well with Moog units. It's worth doing if you're also doing the control arm bushings.
And if you haven't replaced the shocks, you'll absolutely want to do that too.
