Chirp with tire rotation after hitting curb
Here's what you don't want to see.
The following users liked this post:
Y2K_Frenzy (07-27-2022)
It doesn’t spin fast enough to wobble..
You might also just open up the caliper and spread the brake pads. This will allow you to move the rotor freely - but you'll need to take the caliper off to do this, anyway.
If you don't see a wobble, I think you will need to do this if you don't see a wobble so you can spin it freely with the brake caliper on and check alignment and see if everything is square.
I'd check runout on the axle before going any further and replacing the axle and removing the bearing and seal is not that difficult a job.
Is the car in Neutral and the emergency brakes disengaged? If the brakes are engaged it will make it more difficult to turn the axle and that rotor should slide on evenly with no binding so you're doing something wrong if you took it off without issue but cannot get it back on correctly. As for the axles if the rear end is off the ground and the car is in neutral it will be somewhat difficult rotating the driveline such as the axles, differential, driveshaft, etc. If you could set up a dial indicator on the axle flange you can check the runout 0.05 is okay not great and in a perfrct world it's @ 0.00 throught a full turn of the axle.
No, the rear axle will not spin like the front hubs will. Sounds as if the parking brake is on or adjusted wrong and you may have damaged it when you forced the rotor back on. I would pull the rotor back off and inspect the park brake shoes for damage. With the rotor off place jack stands under both side of diff so that both tires are off the ground, start engine and place in gear and watch the axle without the rotor to see if it has a lot of wobble.
Save the manuals!
For a qualatative assessment of the spin of the axle, one would need to put the entire rear on jack stands, remove both rotors and compare each side.
I ordered an axle & it arrived yesterday. Maybe I should’ve gotten the dial indicator, but I’m pretty sure the flange is bent since the rotor wouldn’t go when it was held flush up and down.
I’m probably not going to tare into until next weekend though.
Save the manuals!
Get the dial indicator and some V-Blocks. When you take your axle out, you can put it on the v-blocks and confirm it's bent. Doing this will save you a bunch of pain by making sure your axle is indeed bent and not something else, like your torque tube.
I use this tool all the time for all sorts of stuff. ...calibrating my drill press, checking the driveshaft of our jet skis, checking rotors during brake service, etc. In the long run, it will save you money.
apologize y’all for all of the threads. I’m almost in panic mode. eBay backing plate
#32
Save the manuals!
The fact that the caliper bracket is not centered could be a problem. Did you check it with the old axle? (This is what I was talking about with regard to the brake backing plate, which that bracket mounts to. If that bracket is off, I don't think it's a problem with the axle. I think the plate that the bracket mounts to is probably bent. Or the torque tube flange that the plate mounts to could also be bent. The plate is weaker - so hopefully thats it.)
#33
Resolved. Maybe hopefully.
It’s been a busy week but I got it back together and the wheels spin freely. I’ve only driven it around the block a few times so I don’t know if there is any wobble yet. We shall see. Thanks for the help.
#35
I wasn’t in as bad a shape as I thought. It was one of those too tired to think situations. There was plenty of clearance once the caliper was spread. It’s not rubbing but there is a little shimmy around 80 mph. It’s not bad, a passenger might not notice it over the other creaks and rattles. 😂 I did the place an aerosol can next to the rotor, then spin the rotor trick to see if the gap between the can opened and closed and it did. So I don’t know if the rotor or the brake backing plate is bent a little, but it’s not rubbing.
#37
Pads dragging
All was ok as far as the hub being able to spin freely. I drove it a few times without issues but now the brakes are hanging. What could be the cause?
#38
Wrong or dirty fluid, possibly the pistons in the calipers are hanging up or starting to seize. I had to replace one of the fronts on the 99 car recently due to this and just went ahead and replaced both.
#39
Possibly Resolved. Mostly sort of.
I know that I have several threads running about this saga but I think I have it resolved. Resolved enough to get on down the line. I don’t hear any rubbing and it doesn’t have any braking problems other than a soft pedal because it needs to be bled. The axle shaft was bent and I believe that the backing plate was as well. I replaced the panhard bar but the stock one wasn’t bent. The axle bearing and seal were replaced. The seal was leaking but they didn’t really help with the rub. The axle shaft fixed a bunch of the rubbing and then then backing plate fixed it some more. I think that something is still slightly out of square though. Or my new wheel and or new rotor flange is bent. There’s a slight shimmy and the wheel has the slightest bit of in and out play in it when it’s off the ground.. 🤦🏻♂️ Like it’s not snug down all the way on the rotor. When I get the energy I guess I’ll a different tire & wheel on that side to see what it does. It’s supposed to be cold next week so I prob won’t mess with it. At least it’s rolling and stopping without chirping.
