Best panhard rod.
Who makes the best adjustable panhard rod for the money. My car is a daily driver and has never seen the race track so I don't need a hard core race part. I was looking at either a Hotchkis or BMR. I personally like the BMR because you can adjust it on the car. So what are your opinions on these or are there better ones out there.
Thanks
Thanks
Well, best for the money is subjective. A high quality PHR is worth the extra money spent, so I'm going to recommend that you at least consider the LG PHR with rod ends. I know that you're not looking for "hardcore" parts, but these are very high quality ends and as such they are reasonable for street use.
If it were me I would avoid the center-adjustable PHR. Not a good idea.
I'm sure you'll get a million opinions, though. This just happens to be mine
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by skewba98z28
So it is okay for me to use the rod ends on the street instead of the ends with bushings. Most of the place's I looked they said the rod ends were for race use only.
Originally Posted by Ferocity02
Mine adjustable PHR with rod ends makes way too much noise. Its banging noise, not tire like noise. It sounds like the rear end is about to fall out. I plan on getting one from BMR with poly/poly ends to replace it.
Oh here it is: XMR-12 and XML-12 for the 3/4 inch right and left hand threads. They are the "Endura 2000 series."
Originally Posted by Cal
Instead of downgrading to that BMR/poly junk, why don't you just replace your bad rod ends with some good QA1 rod ends. They have several models, but their top of the line rod ends are second to none and make no noise at all. Now if I could just remember that part number . . .
Originally Posted by Fulton 1
QA1 makes several grades of rod end...
Yup and the cheap ones are still cheap ones. The XMR series are excellent.
However, most use 3/4" heim joints but some use a 5/8ths heim (Bad Z's and possibly others). So, make sure which ones you have before you order the wrong size.
