installed eibach springs and now bottom out.
Old 10-29-2004, 11:50 AM
  #41
LS1TECH Sponsor
Sam Strano's Avatar
Again, there is a difference between truly bottoming out and hitting the bumpstops. And I'm sure that if you look at your axle, you will find shiny spots right below your bumpstops. I'm not saying that you can't run different springs, or that there won't be a difference between them. I am saying that most of what people feel isn't simply "hitting the bumpstops", but rather how hard they hit, and the car's reaction while coming back off of them....... That's a big realm of the shocks, and again most of these guys have crappy shocks, and that is a receipe for distaster. YMMV, and no two people are alike, but that's generally the case.
__________________
Old 10-29-2004, 01:41 PM
  #42
Moderator
jimmyblue's Avatar
Pee Dee, what are these air custom shocks, where did you
get them, did you get any damping rates specs (bump/
rebound) or profiles?
Old 10-29-2004, 01:46 PM
  #43
YellowToy/A's Avatar
In the past i have heard that spring rates in the 450 range would work well on the frount on a car with Koni shocks. I have also heard that springs rates of 300(stock rate) were OK. I would like to know what springs I should use for a Weekend warrior to handle well at the track but still work on the street. I would not want to lower the car much and i would use koni SA all around.
Old 10-29-2004, 08:56 PM
  #44
JasonWW's Avatar
Proven combinations are 500/125 or 500/150.
I have 550/170 on my lowered daily driver and feel that I could go even a bit stiffer up front, maybe 600 or so without it feeling too rough.
Old 10-29-2004, 11:59 PM
  #45
6shifter's Avatar
I have no issues since installing the Bilstein's... then again... I've never bottomed out.
Old 10-30-2004, 12:19 AM
  #46
nvrstsfd23's Avatar
Default SHocks
What type of shocks should I get with the eibach pro kit. I am looking to add a stereo in the back that will weigh maybe 50 to 100 pounds.
Old 10-30-2004, 07:51 AM
  #47
Viper's Avatar
I use 3rd gen Bilsteins in the back with Eibach Pro's. Sam recommends and carries them. Also, you could call Sam and ask him the same question, he's more than willing to help you out.
Quick Reply: installed eibach springs and now bottom out.
