worth it to upgrade to 1le front springs?
I am planning on some bilstein hd's for my car in the near future and was wondering if i should go ahead and get some 1le front springs at the same time cause i don't wanna do the work twice. Should I even consider getting the rears too? Or should I just keep the stock springs? I won't be doing any autocross or roadracing, I just want my daily driver to handle great on the street without sacrificing any ride height or too much ride quality. Thanks.
Originally Posted by 2FAST4U
If i where you I would buy Knoi SA and 1LE front springs! If you want the car a 1" lower there is a second spring clip on the shocks! Best bang for the buck shock!
Originally Posted by roy
Bilstein HD's and 1LE springs are not the best Combination. The HD's need to be revalved to the stronger 1le Springs .
Well I haven't found a place that sells just the springs so I guess i'll be driving on bilsteins and stock springs for a while. I tried gyrhead, but they said their front springs aren't true 1le's (310 lb/in).
My Set is off a '98 SS. I bought them from someone in late '98 for $50.00. they were supposed to go on my '98 Z, But I never installed them. So I put them on my T/A.
Edit: my Second choice was the SLP eibach/Bilstein Setup
Well I haven't actually tried it but i've heard if you order 1le springs from a dealer they'll give you stock springs instead.
P Mack, I haven't tried the dealers, but I second what BadBlueBuggy said. I contacted GM Parts Direct after not finding the springs, and they sent me two parts numbers which were for stock hieght springs... They were going to sell me the same stuff I had and not tell me they were the WRONG parts. I was quite unhappy.
I'm running front: 1LE springs, koni SA, 35mm hollow sway (and STB)
rear: stock Z28 springs, Bilst 3RD gen, 1LE sway (21mm) (and LCA, PHB, TA..)
Great set up for a daily driver/weekend corner carving. I'd like more camber though. I think the P/N for those front springs is 22132887.
Bought my 1LE fronts from a guy in Fla. They were unused. People let these springs go in the sales forum from time to time. Just keep a look out. Again, awesome springs. Linear, firm yet comfortable, reduce body roll and nose dive, won't drop the undercarriage onto speed bumps...
Originally Posted by BadBlueBuggy
Both part numbers 22132561 and 22132887 (Front 1LE) have been discontinued.
In reality though, 1LE's aren't that much stiffer than stock; I have them. So why knock yourself out to get them? The best thing you can do is get a set of coil overs with ERS springs. That way you can specify any spring rate you want, and set the ride height to anything you want. 500 lbs/in front and 150 lbs/in rear seem to be a proven combo.
What's the deal with convertible WS6's and SS's getting this front spring: 22077196
The 1LE numbers are 22077197 and 22077195. So in the 96 spring a stock spring, made just for convertibles, what?
Thanks.
Thanks.
Thanks.
Thanks.
22132561 and 22132887 are the Front 1LE numbers and only came stock on the ram air cars before '00.
