Brakes Question
Old Nov 26, 2004 | 09:10 AM
WhtLT1's Avatar
Default Brakes Question
Ok I have a 96 camaro, now if i start to dip into the low 10's/high 9's wat kind of brakes woudl i need? Can I upgrade to LS1 front calipers and just a drilled and slotted rotor and good pads? Or would i have to go with something with a 4 piston design? And for the rears can i just go with a good solid pad and stock rotor and caliper?
Old Nov 28, 2004 | 01:01 AM
Cal's Avatar
Cal
I could be wrong, but I've never heard of anyone needing a brake upgrade for drag racing an fbody. Slotted rotors are for looks only.
Old Nov 28, 2004 | 12:21 PM
WhtLT1's Avatar
Ok kewl, anyone else on the subject?
Old Nov 28, 2004 | 12:24 PM
roy's Avatar
roy
unless your looking for a lighter brake setup. Then I agree with Cal
Old Nov 28, 2004 | 10:16 PM
WhtLT1's Avatar
So basically u guys are sayin, stock rotor adn caliper as long as I have a really good pad I'll be able to stop down from 130-140 before i hit the wall at the end of the return road?
Old Nov 28, 2004 | 11:29 PM
roy's Avatar
roy
That is no problem to stop. Mustangs with a lot smaller brakes are doing the same thing at faster speeds.
Old Nov 29, 2004 | 12:04 AM
dennis68's Avatar
Pro-stock cars run upwards of 200MPH and they stop without a chute all the time.
Old Nov 29, 2004 | 11:25 AM
Ls1LikeNoOther's Avatar
WHAT!!!!! Maybe if they have 1/2 mile or more to stop like at Joliet...
Your nuts, my 180 mph 57 cant stop without a chute..And my buddies 210 mph Lumina cant stop without his chutes either..You need to turn on the NHRA and pay attention bud!
Old Nov 29, 2004 | 12:22 PM
dennis68's Avatar
OK, at the tracks I frequent they have no problems. The old Fremont (Baylands) they had some trouble but Bakersfield, Infinieon, LACR, and Orange County there is ample room.
Old Nov 30, 2004 | 12:27 AM
ok ya if they have 1/2 mile plus to slow the car down...watch NHRA or even IHRA Pro Mod **** ALL cars use shoots...In most classes like that the teams get PENALIZED if they DONT use their parachutes!
Old Nov 30, 2004 | 12:52 AM
dennis68's Avatar
BTW, a stock 02F body will stop from 100MPH in just over 350 feet. Add some decent pads and tires, I'm sure any LS could pull down from 150 in under 500 feet.
I do watch a little TV, although I prefer to actually be there. A buddy runs a nostalgia AA front engine digger. You are correct that most guys usually use their chute, my point was that they don't have to. Watch some half track runs, when they lift or shut down early for whatever reason. They still hit the traps at 170-200 and usually don't pull the chute.
Old Nov 30, 2004 | 10:37 AM
if they are shutting off half track they are probably 150-190 depending on the class and when your shutting off 600 feet early you got a lot less load to contend with.
Old Nov 30, 2004 | 12:06 PM
dennis68's Avatar
I guess I'm not understanding, if you are going 150-190 at the 1/4 mark how does the braking distance change till the end of pavement?
Old Nov 30, 2004 | 08:11 PM
Scott96LT1's Avatar
You shouldn't have a problem with stock brakes and some good pads. The LS1 upgrade would be a nice all around improvement or if you want to do something fairly unique on F-bodies, the C5 brake upgrade is very, very nice and straightforward. I have the standard grey C5 calipers and they don't stand out too much or you can make them stand out with the Z06 reds if thats your thing.
Old Nov 30, 2004 | 11:59 PM
Well there are 2 stripes ET and MPH if your under load till the MPH stripe as oposed to coasting through the MPH stripe?!
