ASR on/off and ABS Inop !?
My SS seems to have a small issue. Sometimes I start it up all is fine, then a while later the ABS Inop will light up and the ASR Off light will come on as well. Then sometimes it does the opposite. Sometimes I cant turn the ASR back on.
I had the ABS Inop issue in my 94 firebird, I just needed to replace a few taillights. Is this the same issue? Does the LED in the spoilers count as well? All the lights look ok to me. No burnt out bulbs.
Thanks for reading this.
Cheers'
Cheers'
Are there wheel sensors or something i can check? Once in a while the low tract light will come one when i dont think it should (example : it did it when i shift from reverse into drive , stopped). Any ideas on what to check? No SES though...*shrug*
Thanks for you help
Thanks for you help
ChevE,
Shoot me an email at gregg.grooters@us.bosch.com explaining exactly how and when the fault appears and I will try to help you figure it out.
are you running bigger (taller) tires on the rear my 01 ta flashes this light when i have my 28 on the rear anf the 26 on the front. has something to do with the speed of the tire rotation?
