Which SFC for me?
1. I have a lift and WILL NOT be using them to jack up the car under any circumstances.
2. I am not sure if I am going with a y-pipe setup or true duals, so if I'm welding some in, I want to be CERTAIN that their will be no fitment issues.
3. Although I most likely won't lower the car any (at most would be if I got Koni's and lowered it just a little), I don't want them to have good clearance. I've seen pictures of the LG Motorsports (G2) with the v-braces....they look like a good product, but from the side it looks weird. So if I go with them, I probably won't use the v-braces.
4. I will drag race some, but never road race/autox any. I want to get close to needing a roll bar, and I will put one in if needed.
5. I don't want to remove the interior, so the Wolfe aren't an option.
6. For some reason, I don't know why, I don't want to go with BMR. Maybe it's because I have learned that you get what you pay for. And just because I have heard some bad stuff about them, I don't want the KBDD.
So basically, unless you guys suggest something else, I think it is basically down to:
1. G2 w/o the v-braces
2. Spohn Tubular (steel or Chrome Moly?)
3. SLP Bolt-in (and replace them if they won't work with my exhaust setup)
Please, any opinions, suggestions, good or bad experiences, pictures....anything that would help me. Thanks!
Clearance issues is no problem whatsoever, the factory y-pipe sits lower than the v-braces, so there ya go.
Here's a bit of good news though... if you choose the Spohn's, I can save you some dough. I'm a dealer for them. If you want a price quote, email me or PM me and I'll get back to you. Let me know the prices you are getting from all the other competitors and exactly what you are looking for and I'll beat it.
I have the SLPs because I plan on running 9s with my Camaro and I wanted the heaviest SFCs available.
John
As for pictures of duals with SLP's. I can never get pics to upload. I always get some stupid error message.So, if you PM me your e-mail, I can send them to you that way, or maybe someone could host it?
BTW I got to push my car through some pretty curvy roads. It handles very tight and responsive, every trun felt like there was more left in the car. My dash no longer pops and farts on bumps or turns. However, my t-tops rattle more now, I think it is mostly the cold weather, but it did slightly rattle when it was hot. As for bolting them in vs welding them in. So far no bolts have backed out. And SLP's really dont reduce ground clearance all that much, I havent really looked to see how much, but I bet they dont sit any closer to the ground than the y-pipe.
First of all, jcarroll845, shoot me a pm or an email to matts22@hotmail.com with a price. And email me any pictures if you have them. Thanks
Anyway, here's what I'm thinking. I'm most likely never going to lower the car. The only way is if I get Koni SA shocks and use the lower perch to lower about 3/4". Shouldn't make a big difference. So clearance shouldn't be a problem but is always nice.
Things I like about SLP:
1. Bolt in available (which I would most likely get and I might weld them later) and if they didn't fit my exhaust or something I could take them off.
2. Stronger/good design
3. More people have them so I get more opinions
4. I can pronounce their name (j/k)
Things I like about Spohn:
1. Tubular, tuck up REALLY close and can't be seen from the side.
2. Come in Chrome Moly, so they likely won't rust as easily.
3. Give more clearance for duals or a 3" catted y-pipe (haven't decided this either)
4. Light weight
5. Less expensive
Now, based on my first post, which do you think I would be happier with? Would the Spohn be plenty strong for a 450 hp car (in the future)? Do the SLP's rust? Are the SLP's that much stronger/better design?
Please give me some help to decide between these two. ANY HELP AT ALL!
And if anyone has any pictures of either of these installed, especially one of the SLP's from the side of the car, please post them, email them to me, or whatever. I have found some pictures when the car is on a lift, but not a side view.
Does anyone have the Spohn's? Can Chrome Moly rust?
Sorry that I'm so paranoid, but this is one thing that if I buy and weld on, I can't take it off and replace it. So I HAVE to do it right the first time. Thanks!
Another thing is the SLPs are very heavy compared to the Spohns, but also a better design for stregnth. If you are looking for a finished product in the 400-500hp range, I don't think you need the extra stregnth.
They both rust if you don't have them coated. These both come coated unless you go with the cheaper SLP weld on version but then you have to find the bolts to bolt it up first to weld it and then you have to finish them.
They both clear almost any exhaust configuration you can come up with (except tips out the side infront of the rear tire).
Lastly is the price difference... and I'll PM you on that issue but let me just tell you the Spohns will be much less expensive.
John
