Which SFC for me?
http://www.spohn.net/product.cfm?productid=1393
I am still looking for pics of SLP SFC from the side of the vehicle. I want to see some ground clearance shots. PLEASE someone point me in the right direction. I have spent A LOT of time searching and haven't seen any. For SFC as popular as these, I know someone has the pics I'm looking for.
Like I said in an earlier post, if you want all out stregnth, SLP is the only way to go and you HAVE to weld them in for maximum strength. If you drive the car frequantly and speed bumps are an issue, than either tubular BMRs or Spohns are the way to go. If I had to choose, I'd do Spohns just for the cost factor. The materials are identical.
MATTS22: Trust me when I tell you... the tubulars are the way to go for your application.
I had posted earlier, I am wondering about rust. Are the SLP's prone to rust? Does Chrome Moly rust, I mean, is it like stainless steel or aluminum?
And I'm still looking for ground clearance pics of SLP SFC.
I'll probably be over to see my car tomorrow and if I go, I'll snap a few digis for you to check out the clearance. It's about 1" - 1 1/2" less clearance than stock. I'd say just slightly more than an aftermarket y-pipe like the SLP y or similar.
It's Saturday! I've gotta go
hhmmmm Guinness!!!TTYL
Here's the link: http://www.wolferacecraft.com/Search...?CategoryID=78
They have some other cool things there too. Good luck with your choice.
I guess what it comes down to is there really just isn't any wrong way to do it... just do it. You will not regret it.
1. I haven't decided on an exhaust setup yet and they might get in the way and need removed.
2. They come powdercoated.
3. They can be welded in just like the "weld-in" version, they just also offer provisions allowing it to be bolted in.
And those Wolfe (non-through-the-floor) SFC look kind of cheap to me. Maybe it is just the picture. I am pretty set on either SLP Bolt-in or Spohn tubular right now.
