1le suspension question
Old Dec 27, 2004 | 05:12 PM
VinnyV's Avatar
Default 1le suspension question
I have read before about being able to lower my car without change out the spings. I have a 02 SS with a slp 1le suspension with the koni shocks. What's the best way to lower my car with this suspension
Old Dec 27, 2004 | 08:01 PM
roy's Avatar
roy
Move the snapring that supports the lower spring perch to the lower position
Old Dec 27, 2004 | 09:09 PM
pkincy's Avatar
That will lower the car about an inch (the support ring lands are about 5/8ths apart.) Unfortunately you still have to pull the springs to do it.
Perry
Old Dec 29, 2004 | 07:33 PM
ibjamin's Avatar
The Koni D/A's don't have the lower spring perch. Only the SA ones have that.
You can pull out the rubber donut from the top of the rear springs. That will lower the rear about 1/2".
George E.
Old Dec 30, 2004 | 07:27 AM
trackbird's Avatar
George E.
He's right. You can't do that with DA's (I have a set). That is only the Koni SA's that have that option on the front shocks.
Old Dec 30, 2004 | 07:43 AM
roy's Avatar
roy
Thanks for the setting the record straight.
Old Dec 30, 2004 | 07:10 PM
pkincy's Avatar
A good machine shop can fix that.
Perry
Old Jan 8, 2005 | 11:05 AM
JasonWW's Avatar
The front springs can be trimmed shorter while still on the car, but a 3/4" drop or so is the most you want to go. More than that just isn't practical as you will bottom out too easily.
The more you lower it, the stiffer the spring you need. So if you want to go lower than 3/4", you will need to replace the springs with some stiffer ones.
Old Jan 8, 2005 | 11:38 AM
roy's Avatar
roy
Originally Posted by JasonWW
The front springs can be trimmed shorter while still on the car, but you need stiffer springs the more you lower it. So only trim it to get a 3/4" drop or so. More than that just isn't practical.
What did you just say or mean?
Thats crazy talk
Old Jan 8, 2005 | 11:51 AM
JasonWW's Avatar
I reworded, does that make sense now?
Old Jan 8, 2005 | 12:50 PM
roy's Avatar
roy
What Imeant was cutting the springs while on the car , Thats crazy.
Old Jan 8, 2005 | 12:59 PM
JasonWW's Avatar
It's been done before. I wouldn't do it (I have nice goodies in my suspension), but VinnyV specifically asked about something like this, so I mentioned it.
The process is this. Jack up the car, remove wheel. Let suspension hang. Use a spring compressor to compress the spring. Take a cutoff wheel and remove whatever you want from the lower, big end of the spring. Rotate plastic cup to new position, release spring pressure, then put everything back on.
Several people have done it.
