Do I need adjustability in a PHR or CA's w/ stock springs/shocks?
I'm trying to get my M6 SS to hook as best as it can on the street while keeping the stock springs n shocks. My first step is a panhard rod and lower control arms, but I'm ignorant to the adjust. vs non-adjust. debate......does anyone have any input for me? What other suspension parts would make a considerable difference that are worth the cash?
The adjustability is key for when you lower the car. When the car is lower, the rear end becomes more off-center, and may cause you rubbing issues. With an adj. phr, you can re-center the rear end and cure most of the rubbing issues.
What are you going to do with the car? Drag Racing? Autocrossing? Or more of a boulevard cruiser/daily driver?
Moderator
Panhard will do zero for hook, it's only working in the
corners. LCAs, maybe a little. Tires, a whole lot.
LCA relocation brackets, a good bit. Torque arm,
depends on the geometry I guess, probably some
bite to be gained.
bite to be gained.
