BMR only bolt-in Relocation Brackets?
Old Jan 10, 2005 | 01:29 AM
amadeus's Avatar
Default BMR only bolt-in Relocation Brackets?
just as titles state, Is BMR the only one who makes bolt-in LCA relocation brackets?
Old Jan 10, 2005 | 09:39 AM
MeentSS02's Avatar
Kleeborp the Moderator™
That I'm aware of...that's what I have on mine, and didn't see any others that came as a bolt in.
Old Jan 10, 2005 | 09:46 AM
NebWS6's Avatar
I don't know actually. If you plan on going to a 12 bolt don't get the bolt in, get the weld on instead, the bolt in won't fit. From what I've found looking around they are the only ones I've found so far, but don't hold me too that.
Old Jan 10, 2005 | 02:40 PM
amadeus's Avatar
ok thank you. I'll most likely buy the bolt in. Idont plan on going 12 bolt any time soon.
Old Jan 10, 2005 | 05:37 PM
2FAST4U's Avatar
No spoon and lg make them too!
Old Jan 12, 2005 | 10:52 PM
dan102877's Avatar
I have heard that LCA's are needed when the car is lowered. Is this correct? And what is the reason for them? Thanks.
Old Jan 12, 2005 | 11:08 PM
DARK AGE 53's Avatar
There sites only show the weld-on type, I believe BMR is the only company that makes the bolt-on relocation brackets.
Old Jan 12, 2005 | 11:34 PM
skewba98z28's Avatar
If your talking about LCA relocation brackets being needed when lowering your car. The answer is yes and no. If you want to be able to do a burnout and not wheelhop or ever try to hook real good which I'm sure you do. But if you just drive your car and don't ever floor it then no you don't need them. All they do is level you LCA's back out so that they aren't at an upward angle. With them at an upward angle you are losing traction. I installed mine about 3 months ago and I could kick my a$$ for not doing it before. They made a big difference. It seems like the car plant's the rearend a whole lot better. I got mine used in perfect condition for $65 shipped definetly worth. Now if my GS-D3's will ever come in I will really be able to try them out.
Old Jan 13, 2005 | 12:17 AM
dan102877's Avatar
Awesome! FYI....I just put GS-D3's on all 4 corners! Holy crap! Huge difference! You are gonna love them! It's a lot harder to spin them out on dry surface, and in the rain they are freaking amazing! Well worth the money!
Old Jan 13, 2005 | 08:18 AM
MeentSS02's Avatar
That is partially correct...bolt-on relocation brackets will actually fit on a 10-bolt and a Strange 12-bolt. They won't fit on a Moser 12.
Old Jan 13, 2005 | 08:29 AM
slt200mph's Avatar
If you like the GY GS-D3 you ought to try the Yokohama AVS Sports...I have run them both and like the Yokohama much better ...plus they wear better than the GY
Old Jan 13, 2005 | 09:39 AM
dan102877's Avatar
Maybe I will after I run these out. But these are awesome!
