BMR Parts on order
Originally Posted by Texas_WS6
has anyone had any bad experiences with these parts?
Check out www.installuniversity.com for installation info.
If you have a welder then weld the subframe connectors. I had mine installed today - tubalor - and it took them 30 minutes but thanks to the instructions they charges me the 2.5 hour rate. Edit; they took 30 bucks off for finishing earlier.
Originally Posted by absolut_speed
You don't install a pan handle bar, you walk into one.
haha........i didn't even notice that. it's panhard bar. it's one of the easiest things to install with only 2 bolts. if it's an adj. version, you'll have to play with the settings a bit, and then drive around a few miles. when the tires line up with the fenders the same on both sides, and you don't hear any rubbing, you're all done.
later,
Dave
You got me there.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
