Will these brakes fit?
im wondering if these brakes will fit on a stock ls1 set up or will there be some modifications needed?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33563
As long as you use the F-body sized rotor, you will not need to relocate them with any brackets. They will fit fine otherwise. Since you will still be using the F-body pad abutment bracket, you will want to brake pads made for the F-body also.
