running true duals...which SFC???
im running some custom true duals and wondering whats the best sfc....should the DD type subframe tuck well under the car with true duals?? also is the extra weight of the dd style worth it over the less weighing bmr style?
A DD style would be Fine! I had Kenny Brown DDs on my 99 with TDs and it worked perfectly fine. I wouldn't worry about the extra weight, unless your really worried about that extra 100th of a second.
thanks guys...ive seen the two point design has two lower control arm brackets on them..do these fit in or around the stock ones or do you have to cut the stockers out
