Where can I get a grease gun?
I just bought a panhard bar and lca's with the poly mounts. Where can I get a grease gun to grease these with? Can I rent one from oriellys or do I have to buy one? PLease help.
I've used those cheap *** lube guns from Schucks and in some cases they didn't last long enough to lube all 10 fittings in my S10. I would check NAPA and pick up one of their pistol grip hand-pump grease guns for about $25 that accepts a 14oz cartridge. Get yourself a lube whip too if it doesn't come with one.
EDIT: something like this I think would work nicely: http://www.napaonline.com/cgi-bin/nc...&usrcommgrpid=
You can use Marine grease its easily available at any car or hardware store. No squeaking at all out of mine. Don't use a lithium based grease though it will dry up and do you no good.
