3rd or 4th gen bilstein HDs?
Should I go with the 4th gen valving on all four corners or 4th gen up front and 3rd gen in the rear? This setup will be on stock springs with one coil cut. TIA.
Still no information. Does anyone run with the 4th gen Bilstein HD valving up front with the 3rd gen valving in the rear? How does this setup compare with 4th gen valving on all 4 corners?
