from stock z28 to C5 wil it make a differnce??
Originally Posted by baloga41
what are the prats u need to do this ??
Here is a pic of the upgrade. The calipers are still sitting in the box for now. Untill I decide if I want to paint, polish or powder coat them.
Bret
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I read somewhere that in order to run the bigger rotor you need the LG or Bob Bishop brackets, but just in order to run the C5 caliper with the LS1 rotor they just bolt up? Also, is there even a performance difference between the C5 dual piston front calipers and the LS1 dual piston front calipers?
I emailed LG but did not get a reply is there any other places that i can buy the brakets from?????
Originally Posted by jargan04
Call LG and ask for Matt. He will take care of you. If you dont want to cut your spindle then the LG bracket is the only one. The other bracket makes you cut the caliper brackets mounting tabs off it. LG kit just bolts up and unbolts if you need to go back to stock.
It's a bit of a long distance call from Bahrain, they are far enough away that their local time is 8 hrs ahead of Texas. I suspect someone will contact you soon (I passed this along to a friend).
Yes a corvette caliper bill bolt right up with out any problem. There is no performance gain from going to a vette caliper and keeping the fbody rotor.
Yes but they sure are prettier, and for my LT1 either way will be a huge increase. Just not sure if the extra $250 for brackets would be worth it. Are the C5 calipers and rotors any more expensive than LS1 calipers and rotors? If I got the C5 caliper and LS1 f-body rotor, would that use f-body pads?
Why would the gray ones cost more..? I plan to powdercoat whichever set I end up getting because I just made my LT1 calipers look brand spanking new. So I would probably just buy a dirty used set that functions and then do that. I really like the brushed aluminum "corvette" on the C5 calipers.
So is there a performance gain when you go from using the fbody capilers on a C5 rotor, to using a C5 Caliper on a C5 rotor?
The brackets only relocate the caliper? Will it be necessary to use longer brake lines?
One last thing, I thought the vette's had 4 piston calipers up front?
I am very interested in this upgrade, just need some answers
![](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_confused.gif)
![](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I am very interested in this upgrade, just need some answers![](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Bret
so to do this upgrade i can just buy the brackets from LG and a set of C5's front rotors. and that is it right??
