Torque arm clearance issue...
I have a 96 lt1 camaro and i have true duals with longtubes and was wondering if there is a torque arm that will not have any clearance issues with my dual exhaust... i heard spohn torque arms don't fit, anyone know of a torque arm that will???
thanks
thanks
Kleeborp the Moderator™
What kinda torque arm are you looking for? Tunnel mount? Tranny mount? When I had my duals fabbed, I had them fabbed so I could use either. You are obviously more limited. Seeing as how you have Koni SAs, I'm guessing you don't live at the drag strip (I certainly don't). For that reason, I went with the G2 torque arm, but it is $$$. I haven't received it yet, but it fits within the same dimensions as the stocker, and is supposed to be stronger. We shall see...
Well, i dont have any problems with clearance with the stocker, so if the G2 is the same size, it will work, lemme know how it works for you... And no i definitely dont live at the drag strip, but i enjoy straight line racing almost as much as running through the twisties...
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Will do, i need LCA's, a Torque arm and an adj. panhard rod badly, launching and hard corners are killing my rearend...SFC's might work well too, would they give me any clearnace issues with true dals?
