Upgrading Brakes on Z06
Originally Posted by jz06man
thanks for the info- I am planning on a spring project and upgrade the fronts to the Wilwood big brakes... After researching this topic, i feel this upgrade along with cooling ducts, stainless steel brakes lines and D.O.T. 4 brake fuild is the way to go...
Does anyone know where to get a Wilwood Big Brake front system at a better price than L.G. @ $1400 for the set...
no one has his set up with the thick pads .80" so becareful if you find some thing cheaper it will not be the same. I love my setup. You can install mica shims to repel the heat more for 10-20 bucks.
